WEM - Argon 2
by WEM
Argon 2 + SS-200E - Electrosurgical system for endoscopy and colonoscopy surgery
[list]  [*] digital display for argon gas flow   [*] adjustable argon flow between 0 and 5 l/min   [*] adjustment increments for gas flow 0.5 l/min   [*] led indicator for activated argon plasma coagulation mode   [*] led indicator for energized equipment   [*] purge key at frontal panel   [*] adjustment keys at frontal panel   [*] permits use of footswitch operated pencils and WEM catheters   [*] 2 stages of pressure adjustment through subpressure valve at outlet   [*] connection to gas cylinder  [/list]
-LSMAGA
5 years ago
LOOKING FOR THE PM TASK AND SETTING
LOOKING FOR THE PM TASK AND SETTING US MEDICAL INNOVATIONS MODEL SS-200E ESU ARAGON 2 CANADY PKASMA COAGULATORReply
Height7.4 cm
Length 26 cm
Weight5.5 kg
OutPut Frequency480 kHz
Width24.3 cm
Power supply:100-240 VAC / 50-60 Hz autoselect
