Philips - Azurion 7 F12 and C12
Experience the new world of interventional cardiac and vascular performance with the Azurion 7 Series with 12'' flat detector. This new-generation image guided therapy solution supports you in delivering outstanding patient care and increasing your operational efficiency by uniting with workflow innovation.
2Replies5 years ago | Difference between model numbers What is the difference between Philips Azurion 7 M12 and C12?Reply |
- Insightful Live Image Guidance - helps clinicians to determine the most beneficial course of treatment with confidence
- Deep Insight of Coronaries - provides high-resolution imaging over a large field of view allowing you to visualize the aortic valve and a good part of the aortic arch or the entire coronary tree in a single view
- Do More with Flexible Working - team members can work on all activities without interrupting each other
- Full Control at Table Side - allows intuitive control of all applications at the table side to boost efficiency and reduce the need for sterility breaks
- Make Your Day Simpler - on screen, you can easily see information against the distinctive black background where active applications are highlighted
- Manage Dose Efficiently - includes ClarityIQ, x-ray imaging technology that provides high quality imaging for a comprehensive range of clinical procedures, achieving excellent visibility at ultra low x-ray dose levels for patients of all sizes [/list]
