Hologic - ThinPrep 2000
Automated slide preparation systemThrough Hologic's computerized process and patented membrane technology, the ThinPrep 2000 processor controls dispersion, collection and transfer of diagnostic cells from sample to slide. This ensures that the slide is representative of — and reproducible of — the original sample collected in the ThinPrep Pap test vial. Under the precise control of the ThinPrep 2000 microprocessor, a gentle dispersion step breaks up blood, mucus and non-diagnostic debris, then thoroughly mixes the sample. With a series of negative pressure pulses, fluid is drawn though the ThinPrep 2000 filter to collect a thin, even layer of diagnostic cellular material. The ThinPrep 2000 processor constantly monitors the rate of flow through the filter during this process, collecting an appropriate amount of material for testing. The cellular material is transferred to a glass slide using computer-controlled mechanical positioning and positive air pressure. The slide is then ejected into a cell fixative bath, ready for staining and evaluation.
FORUMSView All (5)
0Repliesa year ago | Help with a copy of service manual ? Can i recieve a copy of the service manual ? Reply |
0Replies4 years ago | System error 90 00 Cant find the description of this error or how to fix it. Does anyone know?Reply |
1Reply5 years ago | waste pressure failure-error I am getting this error when i run pneumatic test. i have checked tubing, board, pressure sensors, waste bottle cap, waste bottle connector. everything is good. what might be the problem? Reply |
[list] [*] A rotary drive mechanism gently disperses samples [*] A pneumatic/fluid system, controlled by a microprocessor, monitors cell collection [*] Computer-controlled position and positive air pressure facilitate transfer of cells to the ThinPrep microscope slide [/list]
Height | 150 cm |
Length | 38 cm |
Weight | 19 kg |
Width | 46 cm |
Throughput: Approximately 25 samples per hour Waste container (WxHxD): 15cm x 43cm 15cm Frequency: 47-63 Hz
