Puritan Bennett - Achieva PSO2
Puritan Bennett's Achieva PSO2Extended battery operation and a lightweight, compact design enhance patient quality of life. An internal modem facilitates remote data transfer to clinicians, and an internal dial-in PEEP with flow/pressure trigger sensitivity promotes patient synchrony. Achieva ventilators are highly efficient in terms of oxygen and power consumption compared with other portable ventilators.
FORUMSView All (4)
1Replya year ago | ACCESSORIES need to purchase heated humidifier and external battery Equipment: Puritan Bennett - Achieva PSO2 Reply |
1Reply4 years ago | Troubleshoot-URGENT Please can anyone guide me how to reset the vent of Puritan Bennett Achieva PSO2? Reply |
2Replies6 years ago | How do you replace the internal battery I'm getting a hardware error and while I'm not a betting man, I'd almost bet the problem is the internal battery as it no longer holds any type of charge at all. Going through the process to clear an error, when I apply power to the machine everything appears to function normally for a minute or so and then I get the error. I can't run a Battery Test because it has to be running on battery before you can test it according to the service manual. Unfortunately I've never worked on one of these before and I don't see anything in the service manual about replacing it and being honest, can't see how to open it up. Any info appreciatedReply |
[list] [*] Offers both volume and pressure control ventilation. [*] Flow and/or Pressure triggering for enhanced patient synchrony. [*] Internal dial-in PEEP takes the guesswork out of setting pressure trigger sensitivity. [*] Pressure Support to enhance weaning and improve patient comfort and patient ventilator/synchrony. [*] Expiratory Sensitivity improves patient synchrony by allowing the clinician to adjust the percent of peak inspiratory flow that will cycle the ventilator from inspiration to expiration in Pressure Support. [*] Exceptional battery life for extended mobility. [*] Internal O2 blending for accurate delivery of 21% to 100% oxygen. (PSO2 model) [*] Flow Acceleration Limit. [*] Internal memory and modem allow access to stored data, providing a tool to troubleshoot alarms and evaluate effectiveness of patient settings. [*] Can be used with pediatric patients as small as 5 kg. [/list]
Weight | 33 lbs |
