Bio-Med Devices - 2003FL
by Bio-Med Devices
The 2003FL features a close mounted 0-15 lpm flow meter on the left side that keeps the footprint of this blender much smaller than a flow meter installed on a traditional blender with a DISS fitting. The bleed control knob on the right side allows for gas savings when flows are used at flows higher than 3 lpm (or when not in use) by disabling the bleed flow. When precise accuracy below 3 lpm is needed, bleed flow can be enabled. It also features a bottom DISS port.
| Height | 6.64 in |
| Length | 4.56 in |
| Weight | 2.79 lbs |
| First Outlet Flow Range | 3 to 15 L/min |
| Second Outlet Flow Range | 1 to 15 L/min |
| Width | 5.48 in |
