Bio-Med Devices - 2003P
Standard Low Flow BlenderThe 2003P features the standard low flow blender (with an oxygen DISS fitting on both the left and right sides) with an additional oxygen DISS port on the bottom for added connectivity.The bleed flow (3 lpm) is activated when a flow meter is installed on the right side port, and remains active until either the right side flow meter is removed, or the hoses are disconnected from the gas source.
Height | 5.3 in |
Length | 4.56 in |
Weight | 2.53 lbs |
Width | 4.77 in |
Oxygen Concentration Range: 21-100%
