Fluke Biomedical - VT900
by Fluke Biomedical
The VT900 provides high accuracy for testing gas flow and respiratory medical equipment.
The VT900 Gas Flow Analyzer is Fluke Biomedical’s premium high-accuracy analyzer, designed for comprehensive testing of ventilators, anesthesia machines, flow meters, and other respiratory medical devices. Engineered to meet the demands of biomedical engineers and clinical service technicians, the VT900 provides precise measurements and traceability to global regulatory standards through Molbloc-L calibration. (Generated by AI)
FORUMSView All (6)
-RAShrimpton
Wed May 27 2020
Automation Software
Is there a software available for capturing waveforms for the VT900? I know the VT PLUS HF uses Ansur, but wasn't able to get the same communication with the VT900. Right now, only thing I know of is the Excel add-in. Please help!Reply
-MedWrench Intern
Fri Jun 22 2018
VT650 and VT900 Overview Video
VT650 and VT900 Overview VideoReply
-MedWrench Intern
Fri Jun 22 2018
VT650 and VT900 Gas Flow Analyzers - Setting up your Profiles
Reduce setup time by configuring your Profiles. 20 customizable profiles can be used to configure your VT650 or VT900 to show ONLY the parameters that you need in order to complete preventative maintenance. Reply
VIDEOS
VT650 and VT900 Overview Video...
VT650 and VT900 Gas Flow Analy...
VT650 & VT900 Gas Flow Analyze...
  • ±300 LPM full-range bidirectional flow channel with built-in oxygen, temperature, and humidity sensors for automatic environmental compensation
  • Ultra-low flow and ultra-low pressure ports for maximum accuracy in low-volume, sensitive devices such as anesthesia machines and flow meters
  • External trigger input for advanced testing scenarios and automated workflows
  • Large 7” (17.8 cm) touchscreen for intuitive navigation and simultaneous display of multiple measurements
  • Real-time data review in either color graphs or numerical format
  • Customizable test profiles and remote command support to adapt to specific testing requirements and improve efficiency
  • Onboard memory for short- and long-term test data storage, with USB transfer to PC/CMMS for streamlined reporting
  • Lightweight and portable (3.6 lb / 1.6 kg) with rugged design, carrying strap, and kickstand for both field and benchtop use
  • AC/DC power options plus 8-hour battery life for reliable performance in labs, clinics, or field environments
(Generated by AI)
Weight3.6 lbs
Analyzer/Simulator TypeGas Flow
Battery Life: 8 hours
NEWSView All
Fluke Biomedical VT650 and VT900 Gas Flow Analyzers offer the highest accuracy on the market
Fluke Biomedical VT650 and VT900 Gas Flow Analyzers offer the...
New analyzers deliver ease-of-use and reliability in measurements for all types of ventilators, flow meters, pressure gauges, anesthesia machines, and other devices.
