Sakura - Tissue-Tek DRS-601
by Sakura
Slide strainer
The versatile Sakura slide stainer can also accommodate a wide variety of staining applications. Operating with a user-friendly microprocessor, the DRS 601 system allows the user to facilitate up to 16 different programs to easily identify solutions by name and concentration. The special tab feature facilitates identification of reagents. Staining up to 60 slides per cycle, the Sakura DRS 601 stainer has a compact design that maximizes space, while plastic staining reservoirs eliminate breakage. Removable trays provide rapid changing of solutions, and tray exchange permits different staining procedures. The basket design also reduces cross-contamination and carry-over. The flexible Sakura Tissue-Tek® DRS 601 Slide Stainer is also coverslipper compatible, with the stain and coverslip using the same basket as the Sakura TissueTek Film Coverslipper. Other features of the Sakura DRS 601 Slide Stainer include a quality control program and reagent usage monitoring.
0RepliesWed Jun 02 2021 | Sakura DRS 601 Automatic Slide Stainer Sakura DRS 601 Automatic Slide StainerReply |
11RepliesThu Oct 11 2018 | error 328 Can you help me solve error 328Reply |
3RepliesSat Jul 14 2018 | Sakura Sl8de Stainer DRS601 We have the issue with Sakuea DRS 601 Automatic Slide Stainer. On switch ON we hear a clicking sound & Display keeps blinking. There is no initialization on any motors or the Solenoid for water opening up. All voltages of 5, +/-12 & 24V are available. Connectors have been checked, contacts cleaned.Reply |
| Height | 60 cm |
| Length | 67 cm |
| Weight | 83 kg |
| Width | 117 cm |
