CritiCare - 8100 Poet Plus
by CritiCare
Poet Plus 8100 is the perfect choice for busy departments demanding maximum flexibility, unsurpassed ease of use, and accurate, reliable performance.
Poet Plus® 8100 is the perfect choice for busy departments demanding maximum flexibility, unsurpassed ease of use, and accurate, reliable performance. Respond to every monitoring need, from standard vital signs to conscious sedation. Monitor adults, pediatrics, and neonates in virtually every department, at bedside or in transit. The Poet Plus 8100 mounts quickly and easily to walls, roll stands, and bedrails.               With the compact, lightweight Poet Plus 8100, you focus on your patients, not your monitor. The innovative user interface with simple, one-level menus and dedicated function keys ensures super-fast set-up. The big, bright display with large numerics is easily seen, even from across the room.
FORUMSView All (11)
-mazahar
Invalid Date
system error critical error
My poet plus showing " system error 0c04 at site 2072 critical error.
Please solve my problem.
Thanks
-mazahar
Invalid Date
system error
My poet plus 8100 shows system error 0C04 at site 2072 critical error
Thanks
-Ron Swanner
Invalid Date
Need parts
I am in need of a Poet Plus 8100 for parts or a source for parts. I have one in my shop for repair but no parts are available from the manufacturer and need to try and get this one up and running.
[list]      [*] Easy-to-read 10.4" active TFT color display - view up to 6 waveforms simultaneously.       [*] Easy to learn, easy to use menus, dedicated function keys, and simplified controls.        [*] Smart battery management with rechargeable "hot-swappable" sealed lead acid batteries.        [*] Lightweight design and versatile mounting options - adapts readily to department and transport requirements.      [/list]
Height13.3 in
Length 8.8 in
Weight12 lbs
PrinterThermal line printer
Respiration Rate Range6 to 150
Width12.5 in
