CritiCare - 503DX miniSp02t
by CritiCare
Small, lightweight, and easy to use, the miniSPO2T is ideal for spot-check and transport monitoring in hospitals, clinics, private offices, and EMS.
Detect and assess changes in oxygen saturation in record time. The miniSPO2T™ has the same advanced DOX™ digital technology as our multiple parameter vital signs monitors and lets you evaluate oxygen saturation and heart rate in a broad range of patients, from neonatal to adult. Small, lightweight, and easy to use, the miniSPO2T is ideal for spot-check and transport monitoring in hospitals, clinics, private offices, and EMS.
  • Advanced DOX SpO2 and Heart Rate for routine, periodic spot-check measurements and transport monitoring.
  • With just one compact, ultra-lightweight, handheld monitor, accommodate all of your patients - from neonatal to adult.
  • Unique DOX digital SpO2 technology for improved pulse recognition and artifact rejection.
  • Fully compatible with our comprehensive line of high-quality reusable and disposable sensors.
Pulse Oximetry :
Range: 1% to 99%
Resolution:1%
Accuracy: 70% to 99% range: ±2% 40% to 69% range: ±3% <40%: unspecified
Method: Dual wavelength LED
Heart (Pulse) Rate:
Range: 20 to 300bpm
Resolution: 1bpm
Accuracy: ±1bpm or ±1%, whichever is greater
Displays:
Type: LED
Parameters: SpO2; pulse rate; pulse bar
Status: Sensor; Low Battery
Mechanical:
Weight: With batteries: 280g; 10 oz
Size: Base unit: 14.6cm (H) x 9.1cm (W) x 3.3cm (D); 5.75" (H) x 3.6" (W) x 1.3" (D)
Battery Type: 4; AA alkaline (included); life: 24 hr continuous operation
Environmental :
Operating Temperature: 0º to 45º C;32º to 113º F
Storage Temperature: -20º to 50º C; -4º to 122º F
Operating Humidity: 15% to 90%, noncondensing
Classification:
Type of Protection: Class II equipment
Degree of Protection: Type CF defibrillator-proof equipment
Safety: EN60601-1
