Detecto - 485
by Detecto
Built for use with any standard-size wheelchairs, these scales offer the utmost in comfort for wheelchair-bound patients and long-lasting durability for nursing personnel. Detecto’s 485 incorporates an eye-level physician scale with a detachable ramp, allowing easy movement on and off the platform. The weigh beam is easily read from both sides. The ramp kit (model 3PRAMP) is detachable, allowing the scale to be used as a stand-alone physician scale or may be attached to a Detecto physician scale. 350 lb or 160 kg capacity.
[list] [*] Die-cast weigh beam may be read from either side [*] Electrostatic powder paint finish [*] Metric or imperial options [*] Sturdy steel construction [/list]
| Capacity | 160 kg |
| Kind | Wheelchair |
