Detecto - 475 / 4751
by Detecto
Chair Scale
Frequent weight checks of frail, handicapped, elderly, and dialysis patients can be a tremendous time-consuming task without the proper equipment. Detecto simplifies the task with a selection of innovative-designed mechanical chair scales with wheels. The 475 and 4751 have plastic-molded seats for patient comfort complete with lift-away armrests on both sides and a fold-up footrest for easy access during patient transfers from a wheelchair or hospital bed. The die-cast, dual-sided weigh beam is readable from either side and features white enamel finish. Quality steel construction is apparent throughout the scale, especially in the heavy-duty understructure which is designed for optimal strength and patient safety. No electricity is required. 400 lb x 4 oz / 175 kg x 100 g.
  • Die-cast weigh beam may be read from either side
  • Integral wheels ease transport
  • Lift-away arms and footrest
  • No power required
  • Plastic-molded stea
  • Sturdy steel construction
Capacity175 kg
