Detecto - 7550
by Detecto
Detecto’s 7550 wall-mount wheelchair scale features a unique fold-up storage design that saves space when not in use. The 7550 easily accommodates most wheelchairs with its spacious 32.3-in W x 33-in D (82-cm W x 84-cm D) platform, and yet requires very little floor space when folded up. The slim 6.6-inch / 17-cm profile takes up minimal space when installed in a medical facility hallway, clinical office, or patient room. When you’re ready to weigh, simply lower the platform and the gas spring lifting mechanism will gently lower it into place. The patient may be easily rolled onto the scale, and a platform lip will hold the wheelchair securely in place for weighing. This scale features a high 1,000 lb x 0.2 lb / 450 kg x 0.1 kg capacity for bariatric weighing and two-way ramps.
[list] [*] 2-way easy access ramps [*] BMI calculation [*] Compact vertical fold-up platform conserves space [*] Gas spring lifting mechanism [*] May be used on carpet or hard floor surfaces [*] RS232 serial and USB ports [*] Slim 6.6-inch profile [*] Spacious platform [*] Sturdy steel construction [/list]
| Height | 123.8 cm |
| Capacity | 450 kg x 0.1 kg |
| Length | 99.7 cm |
| Weight | 82 kg |
| Kind | Wheelchair |
| Width | 127.6 cm |
