Pain Management Technologies - Aqua Relief System
by Pain Management Technologies
Aqua Relief System has patented designed wraps that are fitted around the feet and hands. A diabetic sock/glove is worn first, and then a water bladder fits snuggly around your hands or feet to provide a custom like fit. Cold or Hot water is circulated all around the joint providing optimal 360 treatments. Hot water therapy system can provide cool or hot water for 6-8 hours. Provides added compression to further reduce pain and inflammation. Aqua-relief hot cold therapy device reduces chances of skin damage by continuously circulating the fluid. Allows movement of the joint without losing the ice. The machine is re-usable. Can be set from 32 F to 110 F.
Length | 6 in |
Weight | 6 lbs |
Width | 4 in |
