Summit Doppler - 2 MHz Waterproof Obstetrical Probe
by Summit Doppler
The Summit Doppler 2 MHz Waterproof Obstetrical Probe is made for obstetric use in water applications such as water-assisted labor.
The Summit Doppler 2 MHz Waterproof Obstetrical Probe (#SDW) is made for obstetric use in water applications such as water-assisted labor and in the labor and delivery department where the probe needs to be waterproof.
All LifeDop Obstetrical Probes are specifically designed to provide excellent sensitivity and maximum durability. All non-directional probes are completely interchangeable for use on the L150, L250, and L350 Series of dopplers, offering the convenience of choosing one or all for use on the same unit. Most models have user-replaceable cables.
*Note about Certified Items: Items that are certified or that are listed as seller refurbished or used have been cleaned and certified to proper operating specifications, and are in excellent condition.
*Note about Shipping: Our processing team may contact you with an additional shipping cost prior to processing your order for shipments outside of the continental US (this includes Hawaii, Alaska, and Puerto Rico). For international shipping, you must contact us to receive a shipping quote. Feel free to email or call us to get exact shipping costs prior to placing your order.
  • Disclaimer: "The sale of this item may be subject to regulation by the U.S. Food and Drug Administration and state and local regulatory agencies. If so, do not bid on this item unless you are an authorized purchaser. If the item is subject to FDA regulation, I will verify your status as an authorized purchaser of this item before shipping of the item."
Height12 in
Length 6 in
Weight1 lbs
Width4 in
