Huntleigh - Sonicaid D930 Audio Only Doppler
The Huntleigh Sonicaid D930 Audio Only Doppler includes a 3 MHz Fixed Waterproof Probe, carry case, operating instructions, headphones, and gel.An Audio only Fetal Doppler, Huntleigh Healthcare's Audio Dopplex D930 is designed specifically for routine obstetric use in the second and third trimesters. Its fixed 3 MHz probe is waterproof and enhanced with active noise reduction features to produce clear fetal heart tones—in or out of water. Increased probe sensitivity enables the D930 to detect FHR as early as 9-11 weeks and its built-in shock resistance helps protect against bumps or jostling. The Huntleigh Sonicaid D930 Doppler has been designed specifically for obstetric use. Its improved sensitivity enables the easier detection of fetal heart beat in difficult circumstances, for example in obese patients. The D930 , with its high sensitivity probe and excellent audio quality, ensures easy and reliable detection throughout pregnancy.
[*] Handheld obstetric pocket unit. [*] High sensitivity ultrasound for improved ease of use. [*] 3 MHz waterproof transducer suitable for use in a water birthing environment. [*] Integral probe protection and storage. [*] Battery low indicator. [*] Built in loudspeaker. [*] Headphone output. [*] Easy clean transducer for improved infection control. [*] Belt clip and neck-cord (optional) to aid handling.
Height | 140 mm |
Length | 74 mm |
Weight | 295 g |
Width | 27 mm |
[*] Battery Type: 9 Volt (6F22). [*] Battery Life: 500 (1 minute examinations). [*] Auto Shut-Off: [*] When In Use: 5 minutes. [*] With No Signals: 1 minute. [*] Probe Cable Length (fully extended): 3.5 meters (approximately).
