IUL Instruments - Poly Stainer
by IUL Instruments
Slide staining
Automating slide staining is a must for labs that wish to increase their yield. The PolyStainer performs standardized staining procedures that free lab staff from labor-intensive staining procedures. General microbiology and histology labs that seek to reduce sample staining workloads will greatly benefit from its use. Up to 20 microscope slides are loaded in the PolyStainer basket. Next the robotic arm will dip and stir these through four exchangeable plastic wells. Slides can be dipped in a fifth drainable water well that ensures water will be renewed after rinsing each slide basket. Last, slides can be fan dried with or without heat. The four reagent wells in the system allow to perform an extremely broad array of stains.
-MedWrench Crystalyn
Wed Jun 02 2021
https://youtu.be/g9V8wxSW7cg
https://youtu.be/g9V8wxSW7cgReply
3
-davood_la
Thu Mar 08 2018
Microbiology Slide Stainer
Hi the instrument show error code 0001 in the LCD anybody can help me to solve itReply
VIDEOS
  • Walkaway Solution - A one push button operation triggers the entire staining procedure.
  • Unique Design - The PolyStainer was uniquely designed to separate its staining area from the system’s electronics and mechanics, this ensures endurance due to separation from highly oxidative reagents.
  • Staining Protocol Optimization - Ensures no cross contamination by using the PolyStainer’s rinsing well drain to keep rinsing water clean. Speeds stain preparation by drying out slides.
Height400 mm
Length 700 mm
Weight23 kg
Width440 mm
