CME - BodyGuard 545
Multi-Use Pain ManagerFORUMSView All (4)
2Replies5 years ago | Technician Code What is the Technician Code for these pumps? ThanksReply |
1Reply6 years ago | Technician code for CME BodyGuard 545 Greetings, Can you please help me with the Technician code for the BodyGuard 545 to access the service creen? Thanks!Reply |
1Reply6 years ago | Technician Code Hello, Is anyone has the technician code for CME Bodyguard 545 epidural pump? My email address is Valentin.boyo@childrens.edu ThanksReply |
[list] [*] Store up to 26 Protocols [*] EMR Ready [*] Air & Mobile Medicine [*] Ultrasonic Air Sensor [*] MediGuard Dose Error Reduction System [*] Auto Bolus Rate Reduction [*] Post-Occlusion Bolus Reduction System [*] 3-Level Access Codes Applications: [*] Labor and delivery [*] Surgery [*] Post-operative pain management [*] Chronic pain management [/list]
Volume to be Infused | 0.1 to 9999 ml |
Height | 112 mm |
Length | 40 mm |
Flow Rate Range | 0.1 to 30 ml/h |
Weight | 390 g |
Flow Accuracy | 5 % |
Width | 89 mm |
FDA AlertsView All
CME America Updates Recall of BodyGuard Infusion Pump System Due...
