Chattanooga - Intelect XT Battery Module
by Chattanooga
The Chattanooga Intelect XT Battery Module is a lightweight Nickel Metal Hydride battery.
Being only 3 lbs, this battery module makes on the go treatments or treating anywhere within your clinic a breeze. The Intelect XT Battery Module is to be used with 2-channel units, and is lightweight when attached to the electrotherapy or ultrasound unit. This system is most often used in rehabilitation and physical therapy.
SERVICE COMPANIESView All Battery Testing Companies
[list]  [*] 10 battery cells self-containing the Nickel Metal Hydride Battery.  [*] The freedom for the user to treat away from power outlets, on the go, or anywhere in the clinc.  [*] Automatic and continual changing battery when unit is plugged into main power supply.  [/list]
Height4.2 cm
Length 30 cm
Weight3 lbs
Width21 cm
[list]  [*] Shipping Weight: 5 lbs (2.3 kg).  [*] Mains Power: NiMH Battery.  [*] Electrical Safety Class: Class 1, Type BF.  [*] Safety Tests: UL/IEC/EN 60601-1, IEC 60601-2-10.  [/list]
