GE HealthCare - Logiq E10
by GE HealthCare
Logiq E10 is based on GE's cSound Architecture platform, which acquires and reconstructs data in a similar manner to an MRI or CT system, allowing for 10 times the processing power of previous systems and 48 times the data. Logiq E10 also eliminates the need for focal zones because the entire image is always in focus throughout the exam; this provides for better image uniformity. Harness a new standard in imaging, advanced tools, and enhanced workflow capabilities to enable you to scan, diagnose, and treat a wide range of patients across a broad spectrum of conditions. The next-generation, LOGIQ E10, is leading the digital transformation in ultrasound, empowering you to make a difference in the lives of your patients, from head to toe, no matter their age or body habitus.
2RepliesWed Nov 26 2025 | E10 powers off When I turn on my E10 i reaches the GE startup screen with the progressbar. Then it stops - a messagebox apperas with an error and it turns off. I never hear the relays clicking. If I turn the machine off at the outlet and wait until it compleatly turns off and then turn it on it starts normally. I do get an battery deteroiated error when booted. If I try to restart (without turning it off at the outlet) it won´t start op again? Is this a common behaviour when the battery is dead? Later: I got a battery communication error - when I pressed the battery icon at the bottom. When I turned the machine off and tries to start it again it stops at the progressbar whatever I do and shows the error message and turns off. Ok, the culprit was the batteries - the machine for some reason won´t start if there is a communictaion error with the batteries. Removed them and now it starts - every time. Have ordered new ones. |
2RepliesTue Aug 05 2025 | Not powerin on Our unit does not want to power on. I made sure the power cable was good and the power switch on the back is ON but the Power button on the main console does not illuminate. After removing both side and rear panels, I troubleshot the main power supply assembly. I found the 120 V going through the power switch in the back, the fuses were good and i could measure the 120V going to the next board. What could be my next step? Reply |
1ReplyWed May 28 2025 | battery replacement procedure Would anyone have the procedure for replacing the battery on the Logiq e10 please? Equipment: GE HealthCare - Logiq E10 Reply |
[list] Shear Wave elastography Contrast Enhanced Ultrasound Data Security Strain Imaging AutoEF 3D GPS/Fusion Needle Guidance Flow Quantification Cloud Connectivity with Trace Imagings Tracify software [/list]
