Conmed - Hall 50
by Conmed
Built upon 50 years of dependable power and engineering expertise, the Hall 50™ System combines precise performance, reliable power and convenient sterilization into one solution that delivers unmatched value for hospitals, surgeons and OR staff. Consistent, Long-Lasting Power: Hall 50™ handpieces with UL-approved autoclavable lithium batteries deliver twice the power, capacity and operating time of a standard battery * Improved Control: Hall 50™ handpieces feature variable speed triggers with 400 levels of speed controlled by how far you pull the trigger– providing more precise manipulation of blade and drill speed. The handpieces have also been engineered to produce less vibration and noise. One-Step Sterilization: The Hall 50™ System is the only powered instrument system that allows the batteries, handpieces and attachments to be sterilized together in the same tray at the same time. The Hall 50™ System is backward and forward compatible which means you can use it with both our old and future equipment – delivering better long term value and giving you more for your investment. Hall 50™ handpieces are engineered with TRI-SEAL™ Technology, an advanced triple-sealing which gives the handpieces superior resistance to moisture intrusion. Hall 50™ handpieces have ingress protection ratings of IPX6 and IPX8, indicating resistance to moisture intrusion in the presence of high pressure water jets and submersion. The Hall 50™ system has the highest IPX rating of any handpiece on the market.
0Replies2 years ago | user manual troubleshooting Equipment: Hall 50 Reply |
0Replies5 years ago | Pro 7300 b I need to locate some of these 7300 B scopes can anyone help meReply |
3Replies8 years ago | 3rd party vendor to perform PM Looking for a 3rd party vendor to perform preventative maintenance on a Conmed Pro 7300B hand piece. Manufacturer recommendation is PM to be performed annually. Thanks Reply |
