STERIS - Amsco 400 Small
by STERIS
AMSCO® 400 Series Small Steam Sterilizers are engineered to be fully compliant with current steam sterilization standards. The 20 x 20 sterilizer is validated to accommodate a maximum of three 25-lb sets (up to 75 lbs) per load, and the 16-inch models can sterilize two 25-lb sets (up to 50 lbs per cycle), per AAMI guidance for processing weights. They also accommodate loaner sets and larger bariatric and orthopedic devices. Also, the AMSCO 400 Series Small Steam Sterilizers prevacuum and steam-flush-pressure-pulse (SFPP) cycles have been validated, per AAMI recommendation, for porous items. Validated “immediate-use” prevacuum and gravity cycles are available, replacing “flash” terminology, and cycles can be customized and named by the user. AMSCO 400 Series software reduces steam and water usage per pound of instruments processed, and the steam-activated gasket requires no lubrication.
1ReplyTue Dec 23 2025 | Amsco 400 series On startup this 1 unit goes into depressurization, 20min. But stops around the 10 min mark. Customer says it sits there all day and they cant use it. Is that a normal part of the cycle on the 400s? Chamber is empty, I can open the door and it makes no difference. When the countdown stops, could it be a calibration issue? What is thia depressurization, is it the sterilizer or the boiler, is it a feature that can be turned off? Reply |
3RepliesThu Mar 28 2024 | Door unsealed alarm Hi Need help on Sm Century 400 with door unsealed alarm. Exhaust and steam manifold have been changed twice. CK1/2 and 14 also have been changed. PRV, door pressure switch also change and calibrated. After starting DART test not even 5 minutes after the seal got activated the error shows up door unsealed alarm. Im struggling to get it resolve and run out of option hence reaching out here for help. Equipment: Amsco 400 small Reply |
5RepliesWed Dec 08 2021 | Leak test failing at 2.2 mmHg/min Is it air or is it steam leaking & where should I look or rebuild? Unit is only 1.5 yrs old. Reply |
[list] [*] Validated for 25 lb. sets [*] Accommodates larger bariatric and orthopedic devices [/list]
| Orientation | Floor Standing |
