Gossen Metrawatt - SECULIFE DP BASE
by Gossen Metrawatt
Precision Digital Measuring Instrument for Pressure Measurement
The SECULIFE DP BASE Precision Pressure Gauge is a high-performance measuring instrument designed for biomedical engineers and clinical technicians. It accurately detects both positive and negative pressure in compatible liquids and gases, making it ideal for use in medical device testing and calibration.
Featuring a clear, easy-to-read LCD display, the SECULIFE DP BASE ensures reliable measurement visibility in any environment. The device includes an RS-232 data communication port for seamless integration with test systems and supports Min-Max measurement functionality for comprehensive pressure analysis.
Digitally calibrated for superior reliability, this precision pressure gauge delivers outstanding accuracy of ±0.1% across the full display range. The SECULIFE DP BASE provides biomedical engineers with a dependable solution for pressure testing in hospitals, laboratories, and medical equipment service departments. (Generated by AI)
[list]      [*] ± 0.1% pressure measuring accuracy      [*] 5 digit LCD display      [*] Programmable digital filter      [*] Digital calibration and zero adjustment      [*] Male Luer connector      [*] Pressure measurement in liquids and gases      [*] Min-Max capture function      [*] RS 232 port      [/list]
Measuring ranges:      [*] 13.50 to 100.00 psi      [*] 701 to 5190 mm Hg at 20 °C      [*] 951 to 7043 cm H2O at 20 °C      [*] 374 to 2773 inches H2O at 20 °C
