Draeger - X-plore 8000 Series
Challenging workplace conditions demand reliable solutions with the Dräger X-8000 series, offers a new level of intuitive handling.The Dräger X-plore 8000 features heavy-duty design with rubber protectors and high ingress protection (IP65) against dust and water jets from any direction. Two battery versions incorporating the latest Li-ion battery technology provide power for at least 4 h or 8 h, respectively. The air inlets are protected from frontal moving debris, ensuring that sparks or water do not come into direct contact with the filter. In work areas requiring explosion protection, the special Dräger X-plore 8700 model provides optimal support. It is ex-approved and can be used in ex-zones 1, 2, 21 and 22.
The Dräger X-plore 8000 was designed to be practically maintenance free, leading to low cost of ownership. The self-check and self-adjustment systems feature advanced temperature and pressure sensor technology to ensure the right flow rate for any environment. The simple and efficient charging system allows rapid charging (under 3h for an empty battery). The unit is designed for fast and easy disassembly for cleaning.
NEWSView All
Robust in design, safe in use - New Drager X-plore
Drger X-plore 8700 (EX) powered air purifying respirator with ATEX approval
