BFW Inc. - Bristol
by BFW Inc.
Bristol is built to hold up to daily rigorous use offering clear, bright-white illumination up to 40,000 LUX at 16″ (40cm).
Its unique 2 button On/Off intensity controller is integrated into the battery holster making an ergonomically compact LED headlight system with reduced battery size and weight. The optic provides a 3position spot size (1, 2, and 3 inches) at 5 intensity levels from 8,000 LUX at 16″ (40cm) at 28 hours of operation to 40,000 LUX at 16″ (40cm) at 10 hours of operation from a single charge.
  • Spot Size at 16″ (40 cm): 1”, 2”, or 3” (2.5 cm, 5.1 cm, 7.6 cm) On/Off, 5 Intensity Levels
  • 2Button Control in Battery Holster: On/Off, 5 Intensity Levels
  • Optic Material: Anodized Aluminum
  • Optic Weight: 0.882 oz (25 g)
  • Battery Weight: 6 oz (170 g)
  • Output Voltage: 11.25V
  • Battery Capacity: 3.1 Ah, 36 Wh
  • Battery Life: > 300 Full Charges
  • Battery Type: LithiumIon
  • 1-Year Limited Manufacturer’s Warranty
LUX/Battery Life
  • Level 1 > 8,000 LUX at 16″ (40cm) /28 Hours
  • Level 2 > 14,000 LUX at 16″ (40cm) /20 Hours
  • Level 3 > 20,000 LUX at 16″ (40cm) /19 Hours
  • Level 4 > 24,000 LUX at 16″ (40cm) /13 Hours
  • Level 5 > 40,000 LUX at 16″ (40cm) /10 Hours
