BFW Inc. - Hatteras
Hatteras is a powerful and dependable light source tested and cleared for use with headlights and endoscopes.
Its robust and ergonomic features make for a powerful and dependable light source that sustains brightness and K color levels well beyond 10,000 hours, reducing costly bulb changes. Hatteras provides a unique standby feature: when a fiber optic cable is removed from the port, illumination stops – eliminating distracting light in the OR. Simply replace the cable in the proper port, press the standby keypad and Hatteras instantaneously illuminates. Its custom milled, 4-port stainless steel turret accepts BFW/ACMI, Olympus, Storz and Wolf cables.
- 3 digit LED Brightness Display
- Compatible with BFW™ Mobile Stand or Stackable with Most Endoscopic Carts and Booms
- Push Button Membrane with Controls for Fower, Standby, Brightness Up/Down, Display Brightness Levels
- Overheating Prevention System That Shuts Down the Unit in the Event Device Gets Too Hot and Will Enable Fans to Cool The LED
- Input Voltage 100240 VAC, 50/60 Hz @ 1A
- Hospital Grade Line Cord, IEC 60320 Approved
- Two High Breaking Capacity, Slow Blow Fuses, 4A, 250VAC
