Enova Illumination - XLT-125A
The Enova XLT-125A headlamp is versatile with a pivot bracket providing unlimited adjustability to accommodate users individual height and angle of view requirements.
The illumination spot of XLT-125A can be adjusted from 2” to 5+” (5 cm to 15 cm) to give users the exact spot size needed. Coaxial alignment (aligning illumination to the same plane as the users vision) is a breeze with the XLT-125A, with or without loupes.
2Replies5 years ago | Wiring for the cable connector Hello, does anyone has schematic for the wiring of the 4 pin connector that goes into the battery pack? The cable has 4 wires - blue, white, black and brown. ThanksReply |
0Replies6 years ago | XLT-125A Enova's XLT-125A offers 125,000 lux and adjustable aperture for a variable spot-size.Reply |
VIDEOS
- Complete mobility in the OR with no tether to light source
- Uniform illumination spot
- Adjustable illumination spot: 2” – 5” (5-15 cm)
- Co-axial alignment for maximum light penetration
- 5 or 10 hour battery life at full intensity
- 50,000 hours LED life
- Lightweight and perfectly balanced for comfort
Light Source: LED refractive technology
Lamp Illumination: 125,000+ lux
Color Temperature: 6100° Kelvin
Illumination Spot Size: adjustable from 2″ to 5″ (5.08cm to 12.7cm)
Headlight Construction: all aluminum
Headlight Weight: 7 oz/198gm
Headband Construction: rigid plastic with double removable foam pads
LED Warranty: 5 years
Battery: rechargeable lithium-ion (charger included)
Battery Life: 10 to 24 hours with the PP4 (4-cell) battery; 5 to 10 hours with PP2 (2-cell battery); 4 to 8 hours with Freestyle Battery
Battery Pack Dimensions: PP4 is 3 X 4 X 1″ (7.9 X 10.2 X 2.5 cm); PP2 is 2.25 X 4 X 1″ (5.7 X 10.2 X 2.5 cm); Freestyle is 2.5 X 5.5 X 1.5″ (6.4 X 14 X 3.8 cm)
Battery Pack Weight: PP4 is 9 oz/255g; PP2 and Freestyle are 7 oz/198g
