Enova Illumination - PLT-100A
by Enova Illumination
The PLT-100A has an illumination spot that can be adjusted from 2” to 5” (5 cm to 15 cm) to give you the exact spot size needed.
The pivot bracket of the Enova PLT-100A headlamp provides unlimited adjustability to accommodate users individual height and angle of view requirements. Coaxial alignment (aligning illumination to the same plane as users vision) is a breeze with the PLT-100A, with or without loupes.
-MedWrench Intern
7 years ago
PLT-100A
Enova's PLT-100A offers 100,000 lux with Pure Light Technology, giving users high Color Rendition (CRI 95)Reply
VIDEOS
PLT-100A
  • Complete mobility in the OR with no tether to light source
  • CRI 95 (Color Rendering Index)
  • True color rendition of anatomy and reduced eye fatigue
  • Adjustable illumination spot: 2” – 5” (5-15 cm)
  • Co-axial alignment for maximum light penetration
  • 5+ hour battery life at full intensity
  • Lightweight and perfectly balanced for comfort
Light Source: LED refractive technology
Lamp Illumination: 100,000+ lux
Color Temperature: 4500° Kelvin
Illumination Spot Size: adjustable from 2″ to 5″ (5.08cm to 12.7cm)
Headlight Construction: all aluminum
Headlight Weight: 7 oz/198g
Headband Construction: rigid plastic with double removable foam pads
LED Warranty: 5 years
Battery: rechargeable lithium-ion (charger included)
Battery Life: 10 to 24 hours with the PP4 (4-cell) battery; 5 to 10 hours with PP2 (2-cell battery); 4 to 8 hours with Freestyle Battery
Battery Pack Dimensions: PP4 is 3 X 4 X 1″ (7.9 X 10.2 X 2.5 cm); PP2 is 2.25 X 4 X 1″ (5.7 X 10.2 X 2.5 cm); Freestyle is 2.5 X 5.5 X 1.5″ (6.4 X 14 X 3.8 cm)
Battery Pack Weight: PP4 is 9 oz/255g; PP2 and Freestyle are 7 oz/198g
