GE HealthCare - Precision 600FP
by GE HealthCare
The Precision 600 flat-panel classical R&F is a system that fits any current room.
Combining space-saving design with vivid imaging the Precision 600FP is a state-of-the-art flat panel detection system that allows dynamic performance and comprehensive dose management. Combine these benefits with GE's proven history as a trusted partner for service and support and you know you’re getting a system committed to helping you make every fluoro image count.
0RepliesThu May 09 2024 | Vibration & Deflection Criteria for GE Precision 600FP What is the vibration & deflection criteria of this equipment for Engineer to analyze & design properly the supporting frame? Reply |
2RepliesWed Jul 11 2018 | GE Precision 600FP Does anyone have any feed back on the reliability of this room? Reply |
A cesium iodide based flat-panel detector and super noise reduction coupled with a comprehensive post-processing and visualization suite make for ultra-vivid imaging.
Precision 600FP includes features such as grid controlled pulse, adjustable frame rate and dose settings, and virtual collimation that allow reduced dose for you and your patient.
We designed Precision 600FP to be bariatric friendly and easy to use with flexible tableside controls.
The small footprint is designed to fit your current fluoro room and GE’s reliable service support is always there to assist you when needed.
Precision 600FP has a 600-pound weight capacity and a 21-inch caliper opening. At 17 inches by 17 inches, the dynamic flat panel detector offers significantly more anatomical coverage as well as broad dynamic range, uniform brightness edge-to-edge and no pin-cushion distortion. Advanced filters reduce noise without inducing lag to ensure crystal-clear images.
A color LCD touch panel with backlit buttons allows full table-side operation, including review and adjustment of generator settings and dose parameters. In addition, the tower is fully motorized for ease of movement and its controls can be operated with either hand.
Precision 600FP is equipped with an easy to use, lightweight wireless digital x-ray detector and its bucky trays rotate for easy positioning
