Planmeca - Proline PM 2002
The Proline PM 2002 is a dental panoramic film based x-ray.
FORUMSView All (3)
0Replies13 days ago | PM2002 ec temple rest motor timeout error Is there a way to adjust the temple rest motor time out. I have had to disable the temple rest in order to avoid these errors. Also how does on access the temple rest motor? There are 4 screws but the chin rest assemble prevents the cover removal. Thank you in advance Reply |
0Repliesa year ago | ???? ?????? ? ?????????. ?????????? ?????????? ? ?????? ?????? ? ?????????.Reply |
1Reply6 years ago | Service manual Can you help me with the service manual of the orthopantomograph planmeca 2002 please, I need it!!Reply |
- Pediatric, automatic double TMJ, vertical segmenting, and sinus exposure settings
- High frequency, constant potential DC generator
- Generator: DC, constant potential, micropreocessor controlled
- 80kHz
- 0.5 x 0.5mm focal spot
- 2.5 mm AI total filtration
- Anode Voltage: 60-80kV
- Anode Current: 4-12mA DC
- Exposure Time: 5-18s
- Film Size: 15 x 30cm; 12.5 x 30cm
- Cassette: flat
- SID: 480mm (19″)
- Magnification: constant 1.2
- Line Voltage: 100/117/220-230/240V; 50/60Hz
- Line Current: 8-16A
- Dimensions: 60″W x 40.5″D x 86.5″H
- Weight: 237lbs
