Skytron - 3505 EZ Slide
Surgical Table with 21" Top Slide
Featuring convenient top slide and the highest table height in our portfolio, the 3503 EZ Slide is designed with the surgical team in mind. Imaging and surgical access is easy with 21" of top slide, allowing for movement of the patient through the imaging window with just the click of a button. Featuring our highest table height, the 3503 EZ Slide give comfortable working access to a broad range of specialties.
7Repliesa year ago | Refurbishment Looking at sending some surgical tables off to be refurbished. We can’t afford new ones. Any recommendations for companies that do a good job at this? Thanks Equipment: Skytron - 3505 EZ Slide Reply |
0Replies3 years ago | remote control clip issues I've got 3 remote's for this Skytron 3503 EZ slide, and the bed clip seems to fall off often(I'm assuming since i now have 3 of them and all of this occurred before I started working here, but of course it's not on my bench)., the threading is popped out of the back of each one. Does anyone have a source for parts on these controllers?Reply |
- Effortlessly moves the patient toward the C-arm, eliminating the need for risky repositioning
- Articulation weight capacity is never compromised by top slide
- 7 1/2" slide to head
- 13” slide to foot
- Removable leg section for quick accessory attachment and positioning
- Table height adjustable from 25” to 43”
- Maximum table height of 43" gives comfortable, waist-height access for taller surgeons
Tredelenburg | 30 degrees |
Lateral Tilt | 20 degrees |
Patient Weight Capacity | 700 lbs lift and 600 lbs articulation |
