Skytron - 6702 Hercules
by Skytron
Surgical Table with 210 Degree Top Rotation
The 6702 Hercules surgical table provides up to 210° top rotation, allowing you to easily maneuver your patient according to imaging requirements, anesthesia access and positioning preferences. This rotation eliminates the need to reverse the patient on the table, thereby improving patient and staff safety in the OR. Unlike other rotation tables available in today’s market, the 6702’s surface turns independently of the table base, giving you maximum foot room and imaging access. The impressive 1,200 lb lift capacity makes the 6702 an ideal solution for bariatric cases.
2Replies5 years ago | 6702 Hercules Does anyone have the User Manual for the 6702 Hercules Bed?Reply |
| Lateral Tilt | 30 degrees |
| Patient Weight Capacity | 1200 lift and 1000 lbs articulation |
