American Diagnostic Corporation - Adtemp" 429
by American Diagnostic Corporation
ADC's Adtemp 429 noncontact thermometer features an infrared sensor that reads temperature from the middle of the forehead with no skin contact required.
The result is a safe and comfortable experience that maximizes the risk of cross-contamination, without the use of costly probe covers. The infrared sensor simplifies temperature measurement, making it ideal for screening. Other features include dual body/object mode, an easy-to-read backlit LCD display, 30-reading memory, and more. Two AAA batteries included.
  • Infrared sensor simplifies temperature measurement—ideal for screening
  • Measures in about 1 second without patient contact eliminating the concern of cross contamination or costly probe covers
  • Measurement feedback system signals proper operating distance for accuracy
  • Measures at a distance of 4-6cm (1.5"-2.5") from patient's forehead
  • Dual mode - body and object
  • Large backlit LCD display is easy to read
  • Wide Temp Range
  • 30 reading memory
  • Fahrenheit-Celsius switchable
  • Auto-off function after 30 seconds conserves battery life
  • Audible beep when measurement is complete, Night mode mutes volume
  • Compact ergonomic design 5" x 2.06”x 1.75“ ( 52.4mm x 44.5mm x 129.9mm), weighs approximately 3oz (87g) with batteries
  • Uses 2 “AAA” batteries (included)
  • 2 year warranty
Type: Non-Contact
Technology: Infrared
Scale: Dual (°F/°C)
Range °F: 50.0-122.0
Range °C: 10-50.0
Accuracy °F: 0.5
Accuracy °C: 0.3
Response Time: 1 sec
Beeper: Yes
Auto-off: Yes
Memory: 30x
Flex Probe: No
Needs Sheaths: No
Warranty: 2 Year
Battery Type: 1.5v (AAA)
Battery Life: 2000 uses
Latex Content: Latex-free
Packaging:Giftbox
Dimensions: 2.06”x 1.75“ x 5“ ( 52.4mm x 44.5mm x 129.9mm)
Weight: 3oz (87g)
Display: LCD
Operating Environment: 60.8°F-95°F (16°C-35°C)
Storage Environment: -13°F-131°F (-25°C-55°C)
