Huntleigh - Sonicaid FD3
The Huntleigh Sonicaid FD3 Waterproof Rate Display Doppler includes a fixed 3 MHz Waterproof Probe.
The high performance transducer probe enables reliable detection from early gestation right through to delivery, even on obese patients. It offers an unmatched combination of unique automatic noise reduction, acclaimed lifelike fetal heart sounds, and unequaled sensitivity, allowing users to more easily detect fetal sounds in early gestation and mums with raised BMIs (Body Mass Index) than ever before.
- Advanced real time auto-correlation fetal heart rate processing.
- Active noise reduction for crystal clear fetal heart sounds.
- 3 MHz Waterproof Probe suitable for use in a water birthing environment.
- Easy clean probe for improved infection control.
- Integral probe protection and storage.
- Advanced power management with auto switch-off to conserve battery life.
- Low battery indicator.
- Long robust coiled cable enables optimum probe position in all circumstances.
- Built in loudspeaker.
- Headphone output.
- Belt clip.
Height | 27 |
Length | 140 |
Weight | 295 g |
Width | 74 |
- Battery Type: 9 volt 6F22.
- Battery Life: 250 - 1 minute examinations.
- Auto Shut Off:
- When in Use: 10 minutes.
- With no Signals: 3 minutes.
- Dimensions: 140 mm x 74 mm x 27 mm.
- Weight (including probe and batteries): 295 g.
- Probe Cable Length (fully extended): 3.5 m approximately.
