Huntleigh - FD1 Plus Dopplex
The Huntleigh FD1 Plus Dopplex Doppler includes a fixed 2 MHz waterproof probe, carry case, headphones, battery, gel, and operating instructions.
The handheld FD1 Plus pocket doppler is used to recognize fetal heart beat. The high performance transducer enables reliable detection from early gestation right through to delivery, even on obese patients.
1Reply5 years ago | OLD STYLE PROBE REPLACEMENT I have an older FD1 model. For the probe connection on the main board there are three solder points on the left and one on the right. The probe wire colors were red, black, white, and yellow with a bare ground. The replacement probe has a different color scheme for the probe connection wires. Has anyone come across this issue? Which wires correspond to the old color scheme. Arjo did not know because the unit is so old. The original wiring was on the left top was red, middle left had black and ground, bottom left was white, and the right point yellow was soldered. Reply |
- Advanced real time auto-correlation fetal heart rate processing.
- Active noise reduction for crystal clear fetal heart sounds.
- 2 MHz waterproof transducer suitable for use in a water birthing environment.
- Advanced power management with auto switch-off to conserve battery life.
- Long robust coiled cable enables optimum transducer position in all circumstances.
