MDPro - MP-30
The MDPro MP-30 Twins Fetal Monitor includes 3 probe belts, 2 waterproof ultrasound doppler probes, 2 print paper packs, power adapter and cord, and an event marker jack.
The MDPro MP-30 Twins Fetal Monitors features a 7" wide color LED display, data saving up to 150 patients, fetal heart sound recording and playback, and a rotating screen. It also includes multiple language support, various installation methods, a built in quick guide, a waterproof probe, and it is GE/Phillips compatible.
0Replies6 years ago | MP30 Monitor will not Export NIBP measurements into EPIC/HIS Is there an HIS setting or perhaps and interval setting on the MP 30 that allows NIBP measurements to be exported?Reply |
- 7" wide color LED display.
- Data saving for up to 150 patients.
- Rotating screen.
- Various installation methods (notebook style vs wall mount style).
- GE/Philips Paper compatible.
- PC Interface:
- Central Monitoring System: BCM-350.
- Remote control up to 8 monitors by BCM-350.
- Simultaneous Fetal Heart sound Play and Record.
- Unlimited multi language support.
- Wire (RS-232C) and Wireless (Bluetooth) connection.
Height | 80 |
Length | 330 |
Width | 280 |
- Dual pulsed doppler.
- Ultrasound Frequency: 0.985 MHz.
- Intensity: 10 mW/cm2 or less.
- FHR Range: 30 ~ 240 bpm.
- Accuracy: 2% o Range.
- Auto-detection of dual fetal movement.
- External type.
- Frequency Response: DC ~ 0.5 Hz.
- Reference (Zero) Control.
- Measurement Range: 0 ~ 99 units.
- Printer:
- Thermal Array Type.
- Print Speed: 1, 2, 3 cm/min, high speed.
- Auto Print: Off, 10 min, 20 min, 30 min, 40 min, 50 min, 60 min.
- Paper Feeding Function.
- Display: 3 Channels (FHR I, FHR II, UC).
- Function:
- Mark Function.
- FHR II Offset Function.
- Auto Print Function.
- Fetal movement print function.
- Multi-language and quick guide function.
- Dimensions: 80 mm (H) x 330 mm (L) x 280 mm (D).
