The QRS SpiroCard Spirometer turns an off-the-shelf computer into a full-function spirometer.
The QRS SpiroCard Spirometer exceeds the ATS Guidelines, out-performs competition and eliminates the need for routine calibration. The QRS SpiroCard spirometer comes equipped with everything you need to begin testing.
Ask a New Question0Replies-StefanOlssonDundeeUni Mon Dec 07 2020 | Mon Dec 07 2020How Does this Device Measure Air Flow Rate I am a student at the University of Dundee, and I am currently working on a project involving the technologies used in Spirometry and was wondering what technology does the Spirocard use to measure the air flow rate. Does it use a turbine in tandem to LEDs and light sensors, or does it use a mesh grid pneumatograph, or a tube with different end radii?Reply |
- Standards: The QRS SpiroCard spirometer provides effective diagnostic tests and meets the following Standards:
- American Thoracic Society (ATS/ERS) 2005 Standard
- British Thoracic Society (BTS) Standard
- National Institute for Health & Clinical Excellence (NICE) Guidelines
- Lung Age Calculation: Lung age is calculated for patients ages 20-84. It is equal to the predicted FEV1 that matches the patients actual FEV1. Lung age may differ based on the predicted equation chosen.
- Patented, Pre-Calibrated Mouthpiece: With the QRS SpiroCard spirometry system, everything the patient touches is thrown away. No sterilization or calibration is necessary, saving time for nurses, therapist and physicians.
- No Batteries Required: The QRS SpiroCard spirometer draws its power from the PC it is connected to via USB port.
| Height | 16 |
| Length | 140 |
| Weight | 57 g |
| Width | 53 |
- Weight: 57 grams
- Height: 53 mm (w) x 140 mm (d) x 16 mm (h)
- Power Supply: Internal: 5Vdc, less than 80 mA. Supplied by the PCMCIA slot.
- Range (BTPS):
- FLOW: 14 liters/second
- VOLUME: 0.5-8 liters
- Accuracy (BTPS):
- FLOW: 5% o indication or 200 ml/sec, whichever is greater for FEF 25-75 and 10% o indication or 300 ml/s whichever is greater for PEF
- VOLUME: 3% o indication or 50 ml, whichever is greater for FVC and FEV1; 10% o indication or 15 L/min, whichever is greater for MVV
- Precision (BTPS):
- FLOW: 5% o indication or 150 ml/sec, whichever is greater for PEF
- Calibration: ATS 3-speed or standard calibration check
- Predicted Normals: Crapo, Cherniack, Morris, Knudson 1983, Polgar, HSU, Roberts, Warwick, ECCS, NHANES III, Zapletal, Wang, Quanjer
- Tests Performed: FVC, Pre/Post Testing, Flow Volume Loop, MVV, SVC
- Measuring Time: Up to 30 seconds
- Sample Rate: 100 samples/sec
- Resolution:
- Flow Rate: 2 ml/sec
- Volume: 1 ml
- Operating Conditions:
- Operating Temp: 15-40C
- Humidity: 10-90% (on-condensing)
- Atmospheric Pressure: 700-1060 hPa
- Storage Conditions:
- Temperature: -15-50C
- Humidity: 90% mx. (non-condensing)
Minimum System Requirements for Desktop, Laptop and Tablet PCs:
- Operating System: Microsoft Windows XP SP3, Vista or 7
- Free Disk Space: 600 MB
- Internet Requirements: Internet Explorer 6.0 SP1 or later
- RAM: 512 MB or higher
- Processor: Pentium III Compatible or higher; 1 GHz or higher (recommended); 500 MHz (min)
- Screen Resolution: 1024 x 768
- Connectivity:
- 1 Available Type II PC Card Slot or
- 1 Available USB Port
