Draeger - X-am 8000
by Draeger
Clearance measurement was never this easy and convenient: The Dräger X-am® 8000 measures up to seven gases, including toxic, flammable gases and vapors, and oxygen
The Dräger X-am® 8000 is a high-performance multi-gas detection device engineered for biomedical engineers and healthcare safety professionals. Designed with a powerful internal pump, it supports hose lengths up to 45 meters, making it ideal for remote and confined space gas monitoring in hospital facilities, labs, or maintenance environments.
Featuring automatic switching between diffusion and pump mode, this detector conserves energy and minimizes wear—prolonging the device’s operational life. Its rugged, compact design withstands harsh environments, while the intuitive three-key interface and easy-to-read color display allow for simple one-handed operation. Standard accessories like the shoulder strap enhance portability and ease of use in the field. (Generated by AI)
Number of measuring gases 1 to 7
Internal pump, activated with pump adapter Yes, optional
Inductive charging Yes
Customer-specific settings when ordering Yes
Shoulder strap included as standard Yes
Catalytic bead sensor DrägerSensor CatEx 125 PR Yes, configurable
electrochemical (EC) DragerSensors: XXS O, XXS CO LC, XXS HS LC, XXS NO, XXS SO Yes, configurable
Electrochemical (EC) DrägerSensors: other sensors/special gases Yes, configurable
Infrared (IR) DrägerSensors Dual IR Ex/CO, IR-Ex, IR-CO Yes, configurable
Photoionization detector (PID) DrägerSensors: PID HC, PID LC ppb Yes, configurable
Automatic measurement range switching for the catalytic bead sensor, catalytic bead sensor, measuring gas: methane Yes, configurable
Assistants: Confined Space, Leak Search, Benzene/Pre-Tube Yes, only when a pump is installed
Event report (incl. shock detection) Yes, configurable
