Draeger - X-am 8000
Clearance measurement was never this easy and convenient: The Dräger X-am® 8000 measures up to seven gases, including toxic, flammable gases and vapors, and oxygen
Specially designed for use with its internal pump, optimized for your requirements The Dräger X-am® 8000 is equipped with a very powerful internal pump. It can be connected with hoses of up to 45 meters in length. A pump adapter makes it easy to switch between diffusion and pump mode at any time. This means the pump is only operated when you actually need it. That saves energy, reduces wear and tear, and thereby extends the lifespan of the pump. Handy and durable, the Dräger X-am® 8000 is intuitive to operate single-handedly using three function keys. The easy-to-read color display clearly lays out all the information for you. Standard accessories include a sturdy shoulder strap, so you can comfortably carry the X-am 8000. Thanks to its compact and robust construction, the device can withstand even the harshest conditions.
Number of measuring gases 1 to 7
Internal pump, activated with pump adapter Yes, optional
Inductive charging Yes
Customer-specific settings when ordering Yes
Shoulder strap included as standard Yes
Catalytic bead sensor DrägerSensor CatEx 125 PR Yes, configurable
electrochemical (EC) DragerSensors: XXS O‚, XXS CO LC, XXS H‚S LC, XXS NO‚, XXS SO‚ Yes, configurable
Electrochemical (EC) DrägerSensors: other sensors/special gases Yes, configurable
Infrared (IR) DrägerSensors Dual IR Ex/CO‚, IR-Ex, IR-CO‚ Yes, configurable
Photoionization detector (PID) DrägerSensors: PID HC, PID LC ppb Yes, configurable
Automatic measurement range switching for the catalytic bead sensor, catalytic bead sensor, measuring gas: methane Yes, configurable
Assistants: Confined Space, Leak Search, Benzene/Pre-Tube Yes, only when a pump is installed
Event report (incl. shock detection) Yes, configurable
