Welch Allyn - Connex Spot Monitor
by Welch Allyn
The Connex Spot Monitor features an easy-to-use, vivid touchscreen display and provides accurate vital signs measurement
The Connex Spot Monitor provides accurate vital signs measurement including blood pressure averaging, spot checking, interval monitoring and custom scoring across patient populations. The device connects wirelessly to a user's EMR and sends vitals to the patient chart from the point of care to help improve efficiency.Its upgradeable design and custom configurations include optional wall unit integration, industry-leading thermometry and pulse oximetry choices, connectivity and other mounting/mobility options. In addition, the Accessory Power Management Stand with WhisperDrive technology features additional power backup, providing up to 17 hours of on-time, alleviating the need to charge the monitor as frequently. Ships standard with one Adult and one Large Adult cuff.
6Replies11 days ago | NIBP accuracy check failure Being a long weekend, I traveled to our satellite location today to perform functional checks on 10 Connex Spot monitors (PN: 71WT/SW: 1.52.00-A0002/Acquired: 2017). Two exceed the ± 5 mmHg tolerance at all four levels (0, 50, 150, and 250 mmHg) and, thus, have failed; a third is not far behind. Questions: 1. How can I adjust these devices' understanding of what "0 mmHg" is WITHOUT a Service Tool license? 2. Would performing the "Restore factory default settings" procedure in the Service Manual resolve this issue? If not, would "pump assembly" or "NIBP Board" do the trick? If a manual action can resolve this common discrepancy, please share how we should proceed. If Service Tool software is needed, we will be unable to repair these assets without sending them to Welch Allyn for repair. Thank you for your attention and guidance. Reply |
1Reply2 months ago | Welch Allyn CSM 74MT - Touch Screen issues Hi all Had a 74MT CSM touchscreen with issues in 2024, tried a few things, ended up replacing the screen and it worked again. Come 2025 the same CSM is having the same issues. Are these touchscreens really that susceptible to failing? Equipment: Welch Allyn - Connex Spot Monitor Reply |
1Reply7 years ago | testing systolic pressure on connex is there a method to correctly verify the systolic pressure on the connex vital signs monitor? They test on the uptake, so we are getting low systolic pressure readings. any advice?Reply |
Height | 24.13 cm |
Length | 20.32 cm |
Weight | 3.25 kg |
Width | 39.37 cm |
