The Priorclave COMPACT 60– ideally suited for confined areas.Operation up to 138oC –2.4 Bar. The TACTROL 2 microprocessor control system has staged illumination giving digital readouts of cycle status and the simple to set control panel features adjustable temperature and time that can be viewed simultaneously. Ideally suited for use in a wide range of applications.
[list]
[*] Easy to install with a single 13 Amp plug
[*] TACTROL 2 microprocessor control
[*] Quickseal single action door closure system
[*] Castor mounted
[*] Forced air cooling
[*] Media warming cycle
[*] Automatic timed freesteaming
[*] Conforms to BS2646-1993, BS5500 Cat.3, European PED 97/23/EC, EMC compliance tested and CE marked including MDD, amongst others
[*] Supplied with two stainless steel mesh baskets
[/list]
SERIES MODELS
Priorclave - PS/MID/C60 - Standard Model
| Chamber Volume | 60 L |
| Internal Diameter | 350 mm |
| Height | 900 mm |
| Length | 620 mm |
| Orientation | Floor Standing |
| Weight | 85 kg |
| Chamber Depth | 625 mm |
| Width | 472 mm |
| Additional Specifications | Chamber Material: Polished grade 316 stainless steel
Operating Range: Up to 138C. 2.4 Bar
Loading Height: 850mm
Minimum space for installation: 472 x 670 x 1395mm (wxdxh)
Heat Input: 3kW |
Priorclave - PS/MVA/C60 - Vacuum Model
| Height | 900 mm |
| Length | 790 mm |
| Weight | 95 kg |
| Width | 472 mm |
Minimum space for installation: 472 x 875 x 1395mm (wxdxh)
Heat Input: 3kW |
