ZEISS - VISULAS Trion Combi
Combi laser workstation
The VISULAS® Trion Combi from Carl Zeiss combines the multi-wavelength laser VISULAS Trion for posterior photocoagulation with the VISULAS YAG III for anterior photodisruption. This multi-purpose laser provides four different wavelengths for the three most common therapeutic laser applications in a single compact workplace for the first time. The VISULAS Trion Combi is excellently suited for performing iridotomies with pre-coagulation: a single touch of the control panel switches the interface from the photocoagulation to the photodisruption mode.
- Space saving and flexible - Both lasers also perform effectively as individual units. The VISULAS Trion can be used in the operating room while the VISULAS YAG III can continue to be used with the combi laser slit lamp.
- Only as much energy as necessary - The VISULAS Trion Combi focuses the optimum amount of YAG laser energy directly to the target thanks to its Super-Gaussian beam profile.
- Variable focus shift - Depending on the procedure the focal point of the aiming beam is set precisely and reproducibly before, behind or directly at the focal point of the disruption laser.
- Gentle laser treatment - The ParFocus™ zoom system of the VISULAS Trion delivers a homogeneous, sharply defined and reproducible laser spot on the retina and minimizes heat-related side-effects on the patient's cornea.
- Enhanced workflow - All controls for both lasers are available on one central control panel with a detachable display.
