ZEISS - HFA II-i
by ZEISS
Visual Field Series
Validated by more than 30 years of research, design and clinical experience, the Humphrey® Field Analyzer (HFA™) is the accepted standard of care in glaucoma diagnosis and management. With over 65,000 installed units worldwide, the HFA is the premier automated visual field analyzer.
FORUMSView All (12)
-chickod
Tue Oct 28 2025
Main Menu Screen
How do I edit an existing patient's information
-GUYMARD
Thu Jun 12 2025
Error system
When opening the device, the screen only displays the model and version information and is blocked at this level.
Equipment: ZEISS - HFA II 740
-Zeta25
Fri Nov 22 2024
Need some help! P Factor Disk (Calibration Disquet) missing and a lot of errors.
Hello.
We have an HFA-II 750i, with the error code xxxxxx: 1>0130009 2>0x0, system startup 16, chamber constants with error and missing the p-factor disk.
When starting up a new exam an error appears,
motor calibration error,
after canceling, i go to de diagnosis menu and tryied to start the calibration,
to no avail, it don't start without de p-factor disk, who is missing...
how can i can get one? (Zeiss Brazil doesn't have it)
After a few time, the errors piled up, like the " error code xxxxxx: 1>0130009 2>0x0 " and the system startup 16.
How can i fix them? Thanks
  • Gaze tracking is a unique fixation tracking system that records if patient is fixating properly while each stimulus is presented.
  • Head tracking ensures proper alignment of the head and eye relative to the trial lens holder.
  • Video eye monitoring helps to position the test eye in the center of the trial lens holder and monitor the patient during testing.
  • Vertex monitoring uses the distance between two corneal reflexes to determine if the patient has moved too far back from the trial lens. The software will flag the movement and ask the operator to realign the patient or re-initialize the system.
  • SITA Standard: A threshold testing method which collects the same amount of information in half the time as the original Humphrey® Full Threshold standard algorithm, without compromising test reproducibility.
  • SITA Fast: A threshold testing method that collects the same amount of information in half the time as FastPac, without compromising test reproducibility
