GE HealthCare - NM/CT 870 DR
by GE HealthCare
Leading clinical discovery is about improving care for as many patients as possible, which is exactly what NM/CT 870 DR was designed to do.
 It’s a premium SPECT/CT system with the added flexibility of a standalone CT that includes the latest advancements in dose and metal artifact reduction technology. It delivers the accurate, reproducible results referring physicians require in a comfortable and streamlined exam experience, so you can lead clinical discovery with hybrid imaging. All our new 800 Series SPECT/CT systems build on the success of the 600 Series with a collection of SPECT technology enhancements that add to the value of nuclear medicine. In addition to the all-new SmartConsole, these enhancements include a new LEHRS (Low Energy High Resolution and Sensitivity) collimator, which can be combined with either SPECT Step & Shoot Continuous scanning mode or our Planar Clarity 2D processing to increase sensitivity and enable a reduction of scan times or injected dose1. It’s called SwiftScan Planar and SwiftScan SPECT.
NM/CT 870 DR includes our Elite NXT NM detectors, designed to address some of nuclear medicine’s biggest challenges. It also includes a 16-slice CT system with IQ Enhancement technology that enables helical coverage speed equivalent to that of a CT scanner at the same table speed2 with a 50-slice wider detector. Not only does this CT technology add clinical value to SPECT images, it can function as an additional standalone CT. These improvements to both SPECT and CT technology are the foundation for quantitative results. Results that are made even more valuable with the advanced applications included with the Xeleris workstation and the new SmartConsole.
SERVICE COMPANIESView All Nuclear Medicine-Gamma Camera Companies
  • Exceptional NEMA resolution for SPECT in a detector box that is 13 cm slimmer
  • Enable reduction of dose or scan times by up to 25 percent with the increased sensitivity of SwiftScan Planar and SwiftScan SPECT
  • Improved small lesion detectability with SwiftScan Planar and SwiftScan SPECT
  • Shorter photomultiplier tubes combined with lean front-end electronics reduce analog noise and improve performance
  • Collimators optimized for high sensitivity, low septal penetration and high resolution
  • Standalone, MITA Smart Dose compliant CT capable of performing 95 percent of today's CT exams
  • Smart MAR helps reduce photon starvation, beam hardening and streak artifacts caused by metal in the body, such as hip implants
  • WideView enables attenuation correction for the entire SPECT FOV
