AngioDynamics - DELTA
by AngioDynamics
AngioDynamics is not only a pioneer in the laser vein ablation market, we’re also the world’s largest endovenous laser ablation company. [b]Easy[/b] Between the Fiber Recognition System, which facilitates fewer steps enabling a shorter procedure set-up, and the MultiMedia Card, which helps manage patient data between the laser and patient files, the Delta laser helps physicians treat more patients with ease. Every component of the Delta laser is designed for high performance. Controls and interconnections are kept to a minimum and carefully placed, making the interface simple and easy to use. In addition, the Delta 810 nm laser is available in 15 or 30 watts for a wide range of clinical applications. [b]Reliable[/b] AngioDynamics is one of the few vein treatment companies to manufacture the laser and fiber components. The Delta laser is hand-crafted in AngioDynamics’ United Kingdom facility, where the world’s first commercial high-power medical diode laser was produced in 1993. Our proven track record of reliability allows us to offer an industry-leading 3-year warranty to ensure the highest quality laser box and service. Every box endures a rigorous testing process throughout assembly and upon completion. Ablate veins with the confidence that AngioDynamics’ equipment is the highest quality available on the market. [b]Proven[/b] With more than 10 years of clinical evidence, the 810 wavelength is the wavelength of choice for many clinicians and has been in use longer than any other wavelength, with the most success data. It was the first laser for endovenous ablation to receive FDA approval, and it continues to effectively treat varicose veins associated with venous disease.
0RepliesSat Mar 19 2022 | Angiodynamic delta 30 How I can use one fiber multiple timesReply |
0RepliesFri Jul 27 2018 | 43 Failed thermistor I turn on the DELTA and display the following message on the screen: 43 Failed thermistor Turn on / off unit To erase I appreciate if you have a service manual or some information about the problem. Thank you. Ing. Sergio Quintero ANTEL sergioquintero@hotmail.comReply |
[list] [*] Immediate activation of procedure presets [*] Plug-and-play functionality [*] Easy tracking of fiber records [*] Enhanced patient data management and processing [*] Expanded data storage [*] Easy data transfer to PC (software available) [/list]
| Laser Type | Diode |
| Weight | 12 kg |
| Wavelength | 810 nm |
