Lode - Corival
by Lode
This product is Discontinued
Lode's Corival Ergometer
The low start-up load of 7 Watt is unique. The Corival can be controlled easily by all known stress ECG and pulmonary devices in the world. The Corival has an eddy current electro-magnetic braking mechanism. The biggest advantage of this system is the accuracy which is one of the most important Lode principles. With this ergometer, the stress tests performed are reliable and reproducible. The workload is adjustable in a range of 7 to 1000 watt. Moreover, the noise level is reduced to a minimum. Easy transportation of the device is possible by a simple retractable wheel.
Lode providing support for the product until 2026
-andriy.sitovskiy
4 years ago
I will buy a bicycle ergometer Lode - Corival (second hand)
I will buy a bicycle ergometer Lode - Corival (second hand). 200$Reply
Height49 in
Length 43.5 in
Weight121
Width17 in
Patient Capacity: 350 lbs
Maximum Workload: 400 watts, 2400 KPm
RPM Range: 1 to 99 rpm continuously variable
