Lode - Corival Recumbent
Lode Corival Recumbent Ergometer
The low start-up load of 7 Watt is unique. The Corival can be controlled easily by all known stress ECG and pulmonary devices in the world. The Corival has an eddy current electro-magnetic braking mechanism. The biggest advantage of this system is the accuracy which is one of the most important Lode principles. With this ergometer, the stress tests performed are reliable and reproducible. The workload is adjustable in a range of 7 to 1000 watt. Moreover, the noise level is reduced to a minimum. This ergometer can be used for obese and elderly test subjects and in rehabilitation settings. The ergometer is suitable for test subjects up to 250 kgs. The Recumbent ergometer is easily accessible for all test subjects.
