Hillrom - Clinitron Rite Hite Air Fluidized Therapy Bed
Clinitron Air Fluidized Therapy beds provide an ideal healing environment for compromised skin by minimizing the forces that cause tissue breakdown: pressure, shear, friction, heat and moisture. Clinitron Rite Hite system’s unique air fluidized therapy minimizes interface pressure, while maximizing the surface’s immersion and envelopment properties to support healing.
The Clinitron Air Fluidized Therapy bed utilizes advanced technology to provide the highest level of wound care for patients with complex, advanced wounds that are difficult to heal and expensive to manage.
0Replies3 years ago | User manual for the Clinatron hospital bed. I need information on how to disassemble this kind of bed to move it to a different location, because the front door is too narrow to push it out the door. Also need to know how to remove the sand to make the Weight less for transport. Is their a user manual for this.Reply |
SERVICE COMPANIESView All Bed Companies
- Clinitron Rite Hite Air Fluidized Therapy supports skin integrity by providing statistically lower interface pressure and superior microclimate management™ surfaces over traditional surfaces1
- Medical grade, silicone-coated bead fluidization promotes a flotation environment that can help improve patient comfort
- Hi/Lo adjustment can make patient positioning and egress easier and can provide a safer working height for caregivers.
- Electric Head of Bed articulation can help accommodate patient’s with respiratory complications
- Optional Clinitron Rite Hite system Patient Helper accessory can help patients change positions in bed and aid in transfers.
Standard Length | 84" |
Overall Length | 92.5" (231 cm) |
Standard Width | 36" (Siderails off); 42" (Siderails on) |
Standard Height | 21.5" |
Therapeutic Patient Weight Limit | 350 lbs. |
