Hillrom - Envella Air Fluidized Therapy Bed
by Hillrom
Bed
The Envella Air Fluidized Therapy Bed, Hill-Rom’s most advanced wound therapy surface, provides the highest quality wound care along the care continuum for patients with complex, advanced wounds. Air Fluidized Therapy accelerates wound healing, reduces complications, and improves patient outcomes for a range of patient acuities, like flaps/grafts, stage 3-4 pressure injuries and DTIs, resulting in more cost effective care across the continuum.
-Patricia Brock
2 years ago
Envella bed
What is the cost to rent an Envella bedReply
-DGold
4 years ago
transfers
any advice on the best way to transfer a patient to sitting at the edge of the bed? Reply
SERVICE COMPANIESView All Bed Companies
  • Superior performance for major skin risk factors.
  • Weight based pressure redistribution in head section.
  • Side transfer helps make it easy and safe for patients to get in and out of bed.
  • Auto leveling bead bath to help maintain immersion for optimal therapy.
  • Head-of-bed angle indicator and alert supports responsive monitoring and protocol compliance.
  • Bed exit with alert silence supports fall prevention protocols.
  • Improved lumbar support allows smooth, and comfortable transition from head-of-bed section into the bead bath.
  • Integrated scale facilitates less disruption of patient.
  • Adjustable patient comfort settings.
  • CPR quick-release handle.
  • Easy to remove, self standing siderails.
  • Central brake and alert.
  • Intuitively designed controls are consistent with other Hill-Rom beds.
Bed
Low position22" (56cm)
High position31.5" (80cm)
Overall length92.5" (235cm)
Overall width40" (101.6cm)
Head elevation range0º - 60º
Bed frame ground clearance3" (7.62cm)
Minimum width of the bead section19" (48.3cm)
Minimum length of the bead section45" (114cm)
Patient weight range70-350lbs (32-160kg)
Maximum patient height74" (188cm)
Bead temperature control range86º - 100º
Caster and Braking System
Caster size6"
Four wheel brakingYes
Brake not set alertYes
Power Requirement
Rated Voltage12 V AC, 60Hz
Rated current10 A
