Thermo Scientific - Shandon Cytospin 2
A centrifuge device
The Shandon Cytospin 2 centrifuge is considered to be the first to employ centrifugal force to isolate and set down a monolayer of cells on slides. The Cytospin 2 can process a maximum of 24 samples in 12 chambers. Shandon Cytospin 2 can accommodate a wide range of samples with the use of Cytofunnel disposable sample chambers, available in size options ranging from 0.1ml to 6ml.
All of our equipment will is fully tested to perform at factory specifications before being shipped.
Includes: > 3 Cytoclips > Power Cord > Full 90 Day Parts and Labor Warranty
FORUMSView All (3)
0Replies2 years ago | cap and rotor stuck in The cap was placed in the instrument and now they are all stuck together. I can not remove the cap and the rotor. What do you advice?Reply |
0Replies3 years ago | Wiring diagram and schematic hi I have a Cytospin 2 and it don't have power I check it power line and fuse and that is OK but for other check I need to Wiring diagram and its PCB schematics any body can help??Reply |
3Replies6 years ago | Cytospin 2 - User Manual Does anyone have a user manual or instructions book for the Cytospin 2?Reply |
Shandon Cytospin 2 Specifications
Sample Chamber Capacity | 0.1 ml – 0.5 ml |
Width | 15.25 inches |
Height | 8.5 inches |
Depth | 21.875 inches |
Height (Lid open) | 22 inches |
Maximum RPM | 2000 |
Minimum RPM | 200 |
Timer | 1-99 minutes |
Acceleration rates | High, Medium, or Low |
Sample Capacity | 24 Samples in 12 Chambers |
